Headlights won't turn on but mostly everything else does.
Old Jun 12, 2018 | 08:31 AM
Konicokirkland's Avatar
Car: 1983 Chevrolet Camaro Sport Coupe
Engine: 2.8L V6
Not too long ago my 83 sport coupe was involved in an accident that resulted in front end damage on my car, ive gotten most of the parts replaced but I'm scratching my head with the headlights, They won't turn on along with the dash cluster lights (the lights for the center console turn on just fine) only illuminating only the left turn arrow and the high beam icon on the dash. Would the problem be my switch even though everything else works fine? Or would it be something else with the wiring itself
Old Jun 18, 2018 | 05:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Fight
Using a voltmeter or test light, probe the 12 AWG red wire going to the headlight switch.
Is there power there?
If no, check for a bad fusible link near the battery.
If there is power on the the
red wire put the switch in the headlights on position.
Probe the
yellow wire at the switch.
Happy Racing !
If You Need To See Brake Lights To Know When To Apply Yours . . . . . . . . . GET OFF THE ROAD IMMEDIATELY!
Old Jun 18, 2018 | 06:00 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Headlights won't turn on but mostly everything else does.
Old Jun 23, 2018 | 10:52 PM
Engine: 2.8L V6
Alright, so I have an update on my headlight situation, I had unplugged the headlight switch and left it it in the car for about a week. I plugged it back in and all of the sudden i had headlights again, Sorta.
Here's a video on my current situation with it:
Old Jun 28, 2018 | 05:05 PM
Hotdogstand's Avatar
I would have to dig out the old shop manual for the wiring diagrams (or you can google search it), but that makes me suspect the switch is failing.
Maybe the "previous owner" somehow managed to get both low beam plugs on one side and both high beams on the other? I've seen stranger things...
Anyway, there's the schematic, courtesy of Austin Third Gen. Just focus on the area in the yellow bubble.
GunnerGTA
Jan 23, 2014 10:14 PM
HiPerf_Chevyman
Dec 25, 2013 11:23 PM
ShaneBuss2
Nov 7, 2010 02:16 PM
cjames9001
Nov 5, 2010 06:36 PM
maksik7
Jul 27, 2002 10:45 PM
