Wiring/Pinning Diagram needed for Firewall Bulkhead Connector
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hey All,
I am looking for a wiring or pinning diagram for the bulkhead connector on the drivers side firewall underneath and behind the mounted relays for a 91 Z28 and an 87 Irocz both with VIN F.
I bought a new body, a 91 Z28 and I need to see how much and what differences there are in the pinning of that connector so I can get my engine wired in.
This bulkhead connector should connect the fuse box to the headlights and the engine harness.
I will be using a painless engine harness and that will handle most of the heavy lifting, but I would like to do this job right.
Thanks,
Thanks,
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Wiring/Pinning Diagram needed for Firewall Bulkhead Connector
C100 diagrams can be found at the bottom of this link.
http://www.austinthirdgen.org/?pid=19
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Engine: 383 HSR EBL
Engine: 383 HSR EBL
mitchberry
Sep 29, 2012 01:29 PM
cmexlr8
Sep 11, 2009 06:35 PM
