coolant temp pegged at 260 and no 12v to dis
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Just put it in new engine and went to start it up,and I have no 12v at main wire to diz,checked it with a test light key on,nothing I never changed anything,just put car back to stock Did I miss something that I unplugged
also the crazy temp gauge is pegged hot I replaced all 3 sensors when I put motor in,thought that would do it Any ides wher I need to go from here thanks
Re: coolant temp pegged at 260 and no 12v to dis
Temp gauge pegged = its wire shorted to ground, most likely
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Thanks I found it,car is running,tapped on gauge and it came back down ..it works somewhat but dont read true already replaced sensor between 1-3 cut
now I can't keep it from boiling gets hot after3 4mins and I can feel the coolant when I grab the hose bubbling its a reman engine new water pump even put a restrictor in place of thermos just in case Only thing not done is rad
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Very common for the temp needle to spaz and get physically stuck against the inside of the gauge housing when you turn the key on. I glued some pegs to the face of my gauge to limit travel of the needle. My temperature gauge is very inaccurate too.
Engine: V6 2.8
Does your car have the air dam beneath the radiator in place?
Use a $30 infrared thermometer to measure temperature of top radiator hose, and report what temperature the fan kicks on.
Engine: V6 2.8
Just noticed you list your car as a Chevelle.
I’ll point out that this is a forum for third gen Camaro and Firebird.
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
I do have a chevelle but I also have a 84 z28 I'm working on now .And I installed a temp gauge in the thermostat housing and the fan came on at 180 .I drove it to gas station and it didnt get over 180. I guess i will just install a aftermarket gauge just to b sure as mine seems to b reading cooler .I also bought a new rad and 180 thermostat
