Small cap swap... Stuck!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Small cap swap... Stuck!
Are you asking what the plugs on the right are for ?
The gray body one is pink and white wire from the body harness coil power and tach.
Close.
Basically I am asking what conectors from a large cap distributor correspond to that conector on the small cap.
If I am getting the gist though, I need to connect it to my tach and a 12 volt power source that is ignition activated?
I have six unexplained connections under the hood, so I'm thinking I just have to find the right one. (I didn't take this apart, it was half installed and now Im trying to finish it)
Engine: Lb9
Transmission: M20
Can you post a picture of the wires in question ?
There are 4 wires for the icm to the ecm
And the other two are ignition power and tach.
There was a jumper going from the coil to the icm. This goes away.
Are you trying to add the Accel 300+ ?
With the large cap distributor, you should have the wide flat connector to the ignition module, and then the connectors to the coil at the top of the cap. The coil connector on the small cap would be the two wires going to the coil on the large cap. Can you dig it?
Engine: Lb9
Transmission: M20
The top connector hooks to the body wiring accessory power and tach
The lower plug hooks to the hei power and tach.
The bottom plug is unlabeled. It might be for icm power on the devorced coil setup.
If that’s the case I’m not sure you can adapt the 300+
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by rbates74
I have six unexplained connections under the hood, so I'm thinking I just have to find the right one. (I didn't take this apart, it was half installed and now Im trying to finish it).
- Rob
Engine: Lb9
Transmission: M20
Looking at the schematic.
The gray body connector should be coming from the body harness. The first picture looks like coil power and tach you could always run the key on and test for power on the pink wire. The bottom connector on the 300+ goes to the icm on the small cap. The large cap one is powered internally I don’t think the 300+ will work. You should call Accel tech support to confirm.
Engine: Lb9
Transmission: M20
Does your oil pressure gauge work or is it a idiot light ?
Looksthakill
Alternative Port EFI Intakes
Feb 13, 2011 08:32 PM
jayk2k3
Aug 20, 2008 07:55 PM
JB97C5
Feb 24, 2007 09:52 AM
