I need help. I speak from Brazil.
Old Jul 31, 2018 | 08:08 PM
Romulo Guerra's Avatar
Hello everyone, I'm going to the end of my restoration of my 1987 Pontiac Formula 305 carb. And now I'm having trouble finishing the cabling.
If you are having trouble understanding, I apologize, I speak from Brazil and I am writing with the help of Google Translator.
There is a loose cable between the engine and the carburetor. a sensor or a valve. I do not know what it is and what it is for. The picture below is for you to try to tell me what it is: https://uploaddeimag...ns/img_5595-jpg
I will eliminate the canister antipollution system, and would like to know if I will have problems related to this.
https://uploaddeimag...ns/img_5594-jpg
I have problems with the headlights, he has his own will. I imported a GUIDE driver module by my mechanic. wonder if this will solve the problem
https://uploaddeimag...31_22-02-17-jpg
https://uploaddeimag...31_22-02-10-jpg
https://uploaddeimag...31_22-02-14-jpg
Old Aug 1, 2018 | 05:04 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: I need help. I speak from Brazil.
You may have better luck in the carburetor forum. I can't open the links from my work computer, so not much help with that. Are you sure it's a carb and not a TBI unit? 86 was last year for carb from the factory? sensor or valve sounds like idle air control valve.
Old Aug 1, 2018 | 09:05 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
1987 was the last year for carbs and 1988 was the first year for tbi. Can you post a picture of the issue?
Old Aug 1, 2018 | 03:59 PM
this straw also belongs to the exhaust system of the carburetor.
Old Aug 5, 2018 | 08:35 AM
Looks like a carb to me; a Q-Jet specifically.
The thing in the first photo looks like one of the vacuum lines for the HVAC control system. Probably the one that comes through the firewall near the heater hoses as part of the HVAC wiring harness, and goes to the vacuum accumulator in the fender in front of one of the wheels. (can't remember which wheel it's near... someone on this forum will know that, though)
I would recommend leaving the canister system alone and putting it back like it came. It's not hurting anything.
I would also recommend getting rid of that rubber fuel line, before it bursts and the car catches fire from fuel spraying out of it. Make or buy a new steel line, again, like it came.
Old Aug 5, 2018 | 01:55 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
your formula looks really great!
on the question of the headlights, i am not sure exactly from your statement on what the problem is, but you are correct that the module labeled Guide is the module that actuates the lights up and down. this could be the issue, however if the motors on the lights just seem to run and run on their own after you flip the light switch to the up or down position, it likely could also be the plastic bushings inside the motors have crumbled, this is a common issue. good news they are easy to rebuild if this is the case. if you find this is the problem get a kit like this
http://www.top-downsolutions.com/Bod...ght-repair-kit
note that likely you could buy the $20 kit that only has the bushings and not the nylon gear, but check first and confirm what you need
Tbi-MAX
Sep 9, 2008 10:51 AM
Xplod
Jul 13, 2002 10:45 PM
yellowiroc2
Mar 18, 2002 01:31 PM
IROCThe5.7L
Theoretical and Street Racing
20
Dec 6, 2001 11:15 AM
toosloz
Mid-West Region
Mar 21, 2001 08:32 PM
