85 trans am radiator fan wire
Old Aug 7, 2018 | 11:45 AM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
Wondering where the fan relay wire (and the relay itself) are located on an 85 Trans Am. The only wire I have disconnected is a tan and white wire that went to a relay on the driver side firewall. Looking up the part number told me that was the fuel pump relay, so I don't think it's that wire. I've been over the schematics, can't seem to find the wire. If I'm unable to find it, I can just run a fused hot wire from the fuse box to an aftermarket relay, right?
Old Aug 7, 2018 | 01:59 PM
Drew's Avatar
Re: 85 trans am radiator fan wire
Fan relay should be on the rad support. Thinking passengers side IIRC.
Old Aug 7, 2018 | 02:34 PM
Car: 1985 Trans Am
Engine: Chevy 355
It must have been removed then, no relay on the rad support anywhere, and no wires in that area. I did freshen up all the looms and moved a few wires around for my application, but all of my wires are accounted for. Where does the fan relay wire start? +12v from the fuse box?
Old Aug 7, 2018 | 04:56 PM
Drew's Avatar
Pretty sure most of them grab 12v power right off the battery cable.
Old Aug 8, 2018 | 07:58 AM
Car: 1985 Trans Am
Engine: Chevy 355
That makes sense, but shouldn't there be a keyed excitation wire?
Old Aug 8, 2018 | 02:33 PM
Drew's Avatar
Yep, but I don't have an early Firebird wiring diagram on hand.
Old Aug 9, 2018 | 08:35 PM
Car: 1985 Trans Am
Engine: Chevy 355
That's the one I can't seem to find, I didn't see it on the C100 diagram, where does it come through the firewall?
Old Aug 10, 2018 | 01:11 AM
Drew's Avatar
It wouldn't be in C100, it'd be in the ECM harness.
Old Aug 10, 2018 | 06:09 AM
Car: 1985 Trans Am
Engine: Chevy 355
That makes sense, I removed the ECM and harness when I went to a carb. I'll run a new wire from the fuse box. Thank you!
Old Aug 10, 2018 | 10:01 AM
Car: 1985 Trans Am
Engine: Chevy 355
What size and color is the factory wiring, if you happen to know off the top of your head? I'm assuming it doesn't handle much current because it just energizes the relay, but I want to be sure.
Old Aug 10, 2018 | 10:34 AM
Drew's Avatar
Pretty sure you'll want to grab a pink w/blk trace, and use that as your 12v keyed, grab a radiator fan switch and wire it into the opposite side of the relay coil for ground. Then run a 12ga or 10ga wire from 12V constant to the fan, and the other wire from the fan to a solid ground. Don't forget to put a fusible link or a good quality fuse (maxi-fuse or better) in the 12v constant. If you want to add a manual switch, T a wire into the fan switch lead, and run it to a switch inside, run the other side of the manual switch to ground... Kind of comes in handy for drive-thrus and unexpected bumper to bumper traffic jams on 100* days.
Old Aug 10, 2018 | 11:45 AM
Car: 1985 Trans Am
Engine: Chevy 355
What would be the purpose of the first switch you mentioned? Couldn't I do a 12v keyed, a 12v constant, and a ground wire (and the other wire to the fan)? Why put a switch on the relay ground, to disable it if I'm working on something? Thanks for the tip on the fuses and manual switch, I'll likely do a manual switch while I'm at it.
Old Aug 11, 2018 | 05:45 PM
Drew's Avatar
The reason to use a fan switch is so the fan isn't on all the time. It doesn't need to be on until the engine heats up past the normal operating temp, and likely won't ever need to be on at cruising speeds either. A temp activated on/off switch only kicks the fan on when the engine is hot enough to need it.
Old Aug 14, 2018 | 06:40 AM
Car: 1985 Trans Am
Engine: Chevy 355
I missed what you meant by switch, I have one. That should do it, I'll probably wire it all up today. Thank you very much!
Old Aug 15, 2018 | 07:02 AM
Car: 1985 Trans Am
Engine: Chevy 355
Wired it all up and it looks/ works great. Thanks for the help!
Old Aug 15, 2018 | 02:46 PM
Drew's Avatar
Well done!
mr420joe
Oct 12, 2009 10:18 PM
iroc192
Dec 16, 2007 07:43 PM
iggy1991
Feb 27, 2005 12:39 AM
aziroc
Jul 19, 2002 02:44 PM
