VATS Problem
Old Jan 6, 2002 | 10:58 PM
Paul Seymour's Avatar
VATS Problem
Hi,
I'm having problems with the VATS system on my '89 GTA.
I have borrowed a module from a fried of mine and matched a resistor to his key and no problems, it starts. I do the same with mine and the security light stays on and the engine will not turn over or engage.
The car had been in storage for over a year and prior to breaking it out there was a very intermittant problem with starting, but 95% of the time, no worries.
Is it common for the VATS module to give trouble, and if this seems like the cause of my troubles where can I get it serviced and how much would it cost. Also I reakon I could fix it my self with a few pointer as my location is down the near bottom of the world.
Many thanks, Paul.
Old Jan 7, 2002 | 11:10 AM
92RSB4C's Avatar
Tell that good friend of yours that his just got lost. LOL In your test, did you use a key or just a resistor? If you used a resistor, then maybe it wasn't the same resistance.
Old Jan 7, 2002 | 01:50 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds like you need a new module. A new module will set itself to the resistance value it sees the first time it is powered up.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
