camaro headlights
Old Aug 18, 2018 | 01:44 PM
Irocguy976's Avatar
Want a title? Post!
camaro headlights
I have a 85 camaro that was wrecked in the front. After replacing the frontend I found that I have low beam healight on the left side only, and I have high beam on the right side only. When I just tried it I have low beam on both, but the right side uses the same headlight for both low and high. left side high beam still inoperable.
Old Sep 4, 2018 | 05:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Don’t Make Light Of This Subject
It sounds like at least one ground wire is not making contact.
With the headlight switch OFF, use an ohmmeter to check the ground wires.
Then you can use a voltmeter to make sure power is going to each filament with the headlight switch on and the dimmer in the appropriate position for the HI-LO beams.
Happy Racing !
Whether It’s A Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
scorp88
Aug 15, 2020 03:07 PM
David W
Aug 25, 2018 08:02 PM
Fechin
Mar 1, 2018 10:51 AM
subedriver
Exterior Parts Wanted
Sep 14, 2016 03:09 PM
