Ignition problem?
Old Aug 29, 2018 | 07:14 PM
84camaro327's Avatar
Ignition problem?
Just bought another 84 camaro 305 it's all there bought a new battery for it everything light wise and stuff works went to crank and got nothing no clicking cranking or anything guy said it had a problem where it would start with 14 volts but not the normal amount how to I fix/bypass this/troubleshoot ? Thanks
Old Sep 4, 2018 | 05:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Not Cranky . . . . SO I AM !!!!!!
Make sure the starter is well grounded, then use a voltmeter or test light to probe the wire going to the solenoid power input.
Make the wire long enuff to bring into the cockpit.
Now, when you try to crank, but there is no click, is there power?
If yes, the solenoid is bad.
Happy Racing !
Whether It’s A Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
Old Sep 7, 2018 | 09:10 PM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
Re: Ignition problem?
mine did this at one point intermentantly, I eventually broke down and changed the lock switch and keys. Went years without a problem until recently. Does the security light come on?
monte-ss
May 7, 2002 01:14 AM
Akshay
Apr 29, 2002 10:16 AM
Akshay
Apr 21, 2002 02:43 AM
