Orange wire on power distribution block
Old Aug 31, 2018 | 06:59 PM
jlay's Avatar
Can anyone tell me where this orange wire on the power distribution block goes? It’s the third one from the top. The car is an 87 Camaro iroc z. Thanks in advance!
Attached Thumbnails Orange wire on power distribution block-ee0828a7-dda6-4e7f-b02e
Old Aug 31, 2018 | 07:08 PM
Drew's Avatar
Re: Orange wire on power distribution block
The book says rear compartment light. But then it also says that any of the wires can be in any position on that side of the block.
Old Aug 31, 2018 | 10:57 PM
jlay's Avatar
Oh crud, ok. It’s the biggest on the block. Can’t tell if I cut it while changing the floor pans or the P.O.
Old Sep 1, 2018 | 07:58 AM
I'd suspect, something very high power... rear window defogger for example.
Old Sep 1, 2018 | 09:02 AM
jlay's Avatar
Ok thanks, it’s a vert so I’m not sure what it would be to. Where does the power come from on the block?
Old Sep 1, 2018 | 09:42 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Power feeding the junction block will come from the back of the fusebox. Should be easy enough to trace that wire while the kick panel and hush panel are removed.
Might be the Power Seat power wire your looking at,..... it's a large gauge Orange wire that leads from the junction block, behind the kick panel, thru the driver rocker loom and then under the seat.
Old Sep 1, 2018 | 10:18 AM
jlay's Avatar
Ok cool, I’ll check that out thanks.
camarojake
May 13, 2013 03:28 PM
cmexlr8
Sep 4, 2012 12:26 PM
hawaii
Apr 27, 2005 08:31 AM
MikeC.86Roc
Jul 11, 2002 10:52 PM
scauffiel
Sep 12, 2001 09:03 AM
