headlight/foglight sticky?
Old Sep 15, 2018 | 09:54 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
im surprised that there isn't a headlight sticky for firebirds. the pop up headlights are kind of sketchy to change. im sure there are 100 ways to do it and of those there has to be one that's easiest.
Old Sep 16, 2018 | 03:30 AM
mcloudy21's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Axle/Gears: Stock
Re: headlight/foglight sticky?
This look helpful
Old Sep 16, 2018 | 08:08 PM
Evilokc's Avatar
Engine: tbi 305
it wasn't the motor I was trying to replace it was the actual sealed beam headlight. turns out its pretty simple.
1) pop up the headlights and unplug the motor and turn the lights off.
2) remove the plastic surround by removing the 4 torque head screws.
3) remove the tension spring on the lower inner corner of the housing. this will allow you to move the light around freely and easily reach all of the screws.
4) the light is held in with 4 phillips head screws 2 upper , 2 lower ,and 2 adjuster screws. remove the 2 upper and lower screws ( dont mess with the adjusters or you will have to adjust your headlights when your done) and the headlight will come out and you can reach the plug behind
5) plug in the new light and reverse order.
Old Sep 16, 2018 | 08:13 PM
Drew's Avatar
The bottom bezel screw holes are slotted. Only need to loosen the lower screws, remove the uppers, and the bezel will slide out of the way.
No reason to remove a bunch of parts to service the headlight assemblies/motors either. Two bolts on the top of the radiator support, two more under the front of the car, and the entire headlight assembly comes right out.
Old Sep 16, 2018 | 09:45 PM
Evilokc's Avatar
Engine: tbi 305
that is correct drew. I pulled mine all the way out because it felt easier but either way works.
mikesprojectZ
Exterior Parts Wanted
Jun 6, 2012 07:23 PM
Rossdaddy63
May 2, 2005 08:27 PM
stage20
Aug 24, 2004 09:47 PM
NastyL98_T/A
Apr 12, 2003 11:24 PM
Jim85IROC
Oct 4, 2001 10:04 PM
