84 TA Anniversary Distributor wiring
Old Dec 6, 2018 | 12:40 PM
84ann's Avatar
I recently picked up an 84 that is pretty complete. One issue I’ve run into is someone stripped the electronics from the distributor and as a result have a poorly running car to say the least and check engine light. I picked up a new distributor but am having a problem locating the electrical connector and wiring. If anyone has any pics or info of where this should be coming off the harness it would be appreciated.
Old Dec 6, 2018 | 02:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 84 TA Anniversary Distributor wiring
There should be a 4 pin male connector by the distributor.
for ccc and x fire.
Old Dec 6, 2018 | 04:00 PM
84ann's Avatar
for ccc and x fire.
should be are the key words. Just wondering where in this harness I should start cutting to recover them and what color wires I’m looking for
Old Dec 6, 2018 | 04:31 PM
Engine: Lb9
Transmission: M20
Wire colors may varies you should refer to a service manual
white,purple/white,tan/blk and black/red. The wires come from the ecm through the body connector in the drivers side kick panel.
Old Dec 6, 2018 | 04:33 PM
Engine: Lb9
Transmission: M20
Old Dec 6, 2018 | 04:43 PM
84ann's Avatar
Found it! Thanks!
Method86SC
Jun 26, 2001 09:49 AM
HybridZ
Jun 20, 2001 10:09 PM
HybridZ
Apr 16, 2001 10:49 PM
