88 Camaro mess
Old 01-15-2019, 04:54 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
88 Camaro mess
88 plain sports coupe. AC was added. In short the wiring is a major issue. I'd like to change the whole thing out. I think the problem is somewhere in the dash. I put a engine harness from a 88 Camaro in it and got rid of a bunch of the stuff someone added. I have no fuel pump power as before. No power to the injectors.as before. But now no power to the spark plugs. Before it would run if you poured gas in the TB. Now nothing. I have a running 89 firebird. With the l03. Can I make it work in the 88 if I use the complete dash and engine harness?
Old 01-16-2019, 12:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 88 Camaro mess
Firebird and Camaro Dash harness are very different....... AKA: not compatible.
Old 01-16-2019, 06:40 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 Camaro mess
Just the connectors? I know that the gauge cluster is totally different in the way it connect's. colors and what they go to is the same ain't it?
Old 01-16-2019, 12:52 PM
John in RI's Avatar
Re: 88 Camaro mess
WAY to different for me to try and explain all the variances,..... do yourself a favor and just find the the proper CAMARO dash harness.
Old 01-16-2019, 05:44 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 Camaro mess
Ok. How about a 89 Camaro?😀 We had a salvage yard crush over 100 third gen a month ago. I found a yard that has a 87 tpi v6 and a few 89s
Old 01-16-2019, 10:56 PM
John in RI's Avatar
Re: 88 Camaro mess
If you use a dash harness from an 89 Camaro in an 88 Camaro than you will need to accommodate ( or bypass ) the VATS. 89 has it and 88 doesn't. If both cars are TBI then most of the other wiring should be plug and play. Stick with another TBI harness to make things as simple as possible. You can convert an MPFI or TPI harness, but I find it best to make things as simple as possible before starting a wiring project like this.
Old 01-17-2019, 06:41 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 Camaro mess
Thank you John. I've rebuilt a few fire damaged harnesses before. I know repining is all different. Do you know the vin code for v8 TBI? Dumb me. Should be the same as the car I have.
Nick7685
05-03-2015 11:46 AM
samseye
09-25-2013 12:44 PM
Pinguiclia
05-22-2013 11:16 AM
un4givin89
Car Audio
11-16-2001 10:07 AM
IROC86
11-15-2000 08:43 AM
Quick Reply: 88 Camaro mess
