Fuel pump in cabin wiring is bad.
Old Apr 25, 2019 | 12:47 PM
Rwright97's Avatar
I ended up troubleshooting and finding out the wires thwt go into the connector where the fuel sending unit plugs in are bad. Ive gotta replace a pink, grey, and black wire. The connector is riveted onto the tank, where can i get another connector? Also, are the pink and grey wires positive wires? I know the black is the ground.
Old Apr 25, 2019 | 12:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel pump in cabin wiring is bad.
Grey is fuel pump power , pink sender. You can either drill a hole in the connector to pass through a new wire or post a ad in the classifieds for the pass through connector.
zzjakect
Mar 20, 2012 06:43 PM
MaxxMitchell
Dec 3, 2004 10:42 AM
