Temp gauge issues
Old May 19, 2019 | 10:59 AM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
Temp gauge issues
Hey everybody I have an 86 z28 with a temp gauge issue. I’ve searched here and haven’t really found my problem. I’ve replaced the temp sender two time with yet the same problem. Turn key on temp gauge moves up right below 100, staring the car temp gauge needs shakes, car running temp gauge pins back almost straight down.. help please and thank you.
Old May 27, 2019 | 12:38 PM
i8myz28's Avatar
Car: 86 z28
Axle/Gears: 3/73's
Re: Temp gauge issues
So I have unplugged the sensor and the needles does the same thing
Old May 28, 2019 | 04:44 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Temper Tantrum
Here’s how to test the temperature gage.
Disconnect the
green wire from the temp sensor.
Clip in a 100 ohm resistor from that wire to the negative battery terminal.
Turn the key to RUN.
If the gage is good it will read about 220°.
Normally when starting, the gage should peg at max however that might not be related to problem.
Happy Racing !
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
jerzeydevil
Mar 6, 2013 02:28 PM
online170
Sep 4, 2007 12:15 PM
StealthElephant
Jan 7, 2004 09:15 PM
THETANK
Dec 22, 2002 11:28 PM
