Is it possible to disable check engine light???
HI, I installed a Holley EFI system in my 87 Firebird 305 engine. Car runs great, however the check engine light (expected) is on. I really don't want to take the dash apart, do you know of any other way to shut it off?
Many thanks in advance,
Louis
Louis
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Is it possible to disable check engine light???
Ccc there is a lamp driver module I think if you remove it the mil will go off.
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/elec...ine-light.html
I think it’s on the passengers side under the dash.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Leave it alone. It will burn out eventually...
Engine: Lb9
Transmission: M20
