Testing the speedometer and tachometer out of the car cheaply
Old Jul 7, 2019 | 07:14 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
So i wanted to upgrade to the 140 mph speedometer and the V6 tach to better match the LS1 in my car. Right after my swap my odometer stopped working. So I picked up a 140mph speedometer and low and behold its odometer is also dead.
So I ordered http://m.odometergears.com/mobile/products/Pontiac/Firebird-Trans+Am/178 and rebuild the odometer. But I wanted to verify I had the needle on right.
So I ordered a cheap signal generator that outputs the same voltage as the input voltage at the selected frequency.
Signal generator on Amazon Signal generator on Amazon
Here is the results.
It's as accurate as it was before, I will replace all the capacitors before I install it in the car to be prudent.
This works for the tach also.
Speedometer is 4000 pulses per mile so the formula is.
4000*speed/60/60=frequency in hz for that speed in mph.
For a v6 tach it's 3 pulses per revolution(ppr), and for a v8 tach it's 4 per revolution.
So for example at 2000rpm on a v6 tach the math is.
2000rpm*3ppr/60=frequency in hz.
Speedometer wire, red 12vdc, black ground, green signal
Red 12vdc, black ground, green signal
Jurrel
Sep 4, 2003 09:49 PM
88FormulaDriver
Jun 4, 2002 10:22 PM
MikeH
Jun 19, 2001 07:10 PM
CamaroX84
Jun 18, 2001 03:31 PM
Kevin S
Sep 14, 2000 12:38 AM
