Why are the Accel injectors so cheaply priced????
Old Jun 17, 2001 | 08:32 PM
CamaroX84's Avatar
I need new injectors for my TPI motor. I was looking at Accel's and Holley's injectors. Accel 24# injectors (Part # 150824)are only $230. Holley injectors (Part # 522-2408) are $470. Why is there such a big price difference? Are the Accel injectors crappy? Or are the Holleys just overpriced? Will these Accel "Universal" injectors fit into a TPI motor? Any help is greatly appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles, Rebuilt 355 TPI L98, Crane 2032 CompuCam - 214/220 @ .050", Crane adjustible fuel pressure regulator, custom burned PROM, stock TPI intake, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Disc Brake Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
New Paint
Best 1/4 Mile Run (with old LG4 motor):
16.760 @ 80.74 MPH
Coming Soon:
Aluminum Drive Shaft
Old Jun 17, 2001 | 09:27 PM
Guest
Guest
Posts: n/a
SVO 24# injectors are even cheaper than the Accel.
The Holleys and GM injectors are just overpriced, plain and simple. Both the SVO and Accel come from Bosch, cant go wrong with that.
Old Jun 17, 2001 | 09:38 PM
CamaroX84's Avatar
So are the Accel 24# injectors and the Ford 24# injectors the exact same thing? If so, why the difference in price? Are the Ford injectors the ones in Summit for $220 for the Mustangs? Both the Accel and Ford injectors will plug in and work okay, right?Thanks.
[This message has been edited by CamaroX84 (edited June 17, 2001).]
Old Jun 17, 2001 | 09:52 PM
Guest
Guest
Posts: n/a
Because Accel wants more money in profit? AFAIK there are no differences at all besides the color. The only thing you might ask about is the design, if its pintle, disc, or has a bunch of holes in it. I think those are both lightweight pintle design.
I have a set of 30# injectors sitting right next to me, an 86 TPI base, and a fuel rail that I think is off an 85, I test fit the injectors and had no problems. I have heard of different orings that are smaller than stock GM orings, but I dont have them on mine.
Old Jun 17, 2001 | 10:00 PM
CamaroX84's Avatar
So will both the Mustang and the Accel injectors fit? Will going to 24# injectors be too big for my motor right now? Will there be any problems or will I actually benefit? My current injectors are bad, so I need to replace them anyways, and I eventually plan on buying a Super Ram, so I figured I should get some bigger ones. All mods listed in sig. Thanks for the help.
New Paint
16.760 @ 80.74 MPH
Coming Soon:
Old Jun 17, 2001 | 10:04 PM
Jason M 91Z's Avatar
I've read that the Accel's use the "Bosch style" pintle, but can't confirm that they're in fact made by Bosch. I wouldn't put it past Holley to sell somebody elses product w/ their name on it. Somebody here bought a Holley in-tank FP for $250 IIRC, only to get the same Walbro 255lph pump that I got for $93 from Ron Gregory over at APE.
-Jason M. 1991 Camaro Z28
Old Jun 17, 2001 | 10:12 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by CamaroX84:
</font>
Yes, those are the ones!! The Accel injectors used to be priced up around the same price as the Holley and GM injectors until recently when the price was dropped to compete with the Ford SVO injectors since they're the same and more people are buying those! The main difference between the injectors is the rating though! Ford rates injectors at a lower fuel pressure so if you bought 24# SVO injectors and put them in your thirdgen they would actually act like 26# or 28# injectors with the higher fuel pressure that our cars require!!
With all that said.... I went through this decision making myself on which injectors to buy! In the end I decided to go over to the classifieds on the camaroz28.com message board and I found a set of 24# LT1 injectors and picked up the entire set for $25... then I sent them to Cruzin Performance (www.cruzinperformance.com) and for $80 they cleaned them, replaced the screens and o-rings, and flow matched them so that they now flow BETTER than they did when they came from the factory!! So basically, I paid $105 (plus slight shipping) for a perfectly good set of 24# injectors instead of over $200!
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.5:1 Compression, Stock TPI ported, 24#/hr LTI injectors, Hedman Shorty Headers, SBC Stock Casting heads pocket ported, Comp Cams XE262-14 TPI Cam, Ed Wright Fast Chip, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Box, Hypertech hot coil!!
Old Jun 18, 2001 | 11:56 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
madmax, the Accel injectors are not from Bosch....some company, can't recall the name right now, produces these injectors for Accel as well as many other places, ie. NAPA and the like.
Old Jun 18, 2001 | 12:27 PM
Mark 89Formula's Avatar
Like 406TPI said, Accel recently switched suppliers. Was Bosch; now it's Siemans (I think). Rich at Cruzin has the scoop. I installed a set of the new 21 lb/hr injectors in January and have been happy with their performance.
Old Jun 18, 2001 | 12:33 PM
UVA3rdGen's Avatar
My friend new a guy he works with on a baha racing team that used to work for rodchester fuel injection. It cost them something crazy like $5.47 to make a fuel injector including overhead. With that in mind $230 dollars does not sound so cheap.
Old Jun 18, 2001 | 03:31 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
<font face="Verdana, Arial" size="2">Originally posted by UVA3rdGen:
My friend new a guy he works with on a baha racing team that used to work for rodchester fuel injection. It cost them something crazy like $5.47 to make a fuel injector including overhead. With that in mind $230 dollars does not sound so cheap.</font>
Toliet paper costs about $.02 per dozen rolls to make too. If it wasn't for markups, no company on earth could turn a profit.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
tazs2000
Jul 15, 2017 08:44 AM
italiano67
Dec 11, 2016 09:21 AM
New2Chevy
Oct 4, 2015 11:27 PM
gixxer92
Sep 1, 2015 04:32 PM
z28_AJ
Aug 27, 2015 08:59 PM
