Double 18guage ground wire - where does it go?
Old Aug 18, 2019 | 12:19 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Got 2 black 18 gauge wires that terminate on the fender into a single connector. Appears to be a ground for a few things. Anyone know what this is for? 2 red lines point to ends, and circle points to area where it is mounted to fender.
Old Aug 18, 2019 | 12:35 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Double 18guage ground wire - where does it go?
Does the ring terminal and crimp look homemade?
IIRC if stock, there would be a hole in the "frame horn" piece that the top of the fender bolts to; and it used a sheet-metal screw with a star washer under the ring terminal to cut through the paint.
I would NOT use a fender bolt or a hood hinge bolt regardless.
Old Aug 18, 2019 | 12:47 PM
LiquidBlue's Avatar
Transmission: MD8
no, looks factory.
Old Aug 18, 2019 | 12:48 PM
LiquidBlue's Avatar
Transmission: MD8
yes, it is a terminal and mounted with a star washer, similar to what is seen near the battery for ground, but the wires are thinner.
Old Aug 19, 2019 | 04:18 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
The grounds are for the cruise control...
Old Aug 19, 2019 | 11:38 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
On my cars these are screwed down just behind the strut tower
Old Aug 19, 2019 | 11:52 AM
LiquidBlue's Avatar
Transmission: MD8
was going off memory where this is screwed, think it was inner fender, need to look to be certain. thanks for the answers guys, now I gotta figure out what part of the cruise control these go into. somehow they broke off.
Old Aug 19, 2019 | 04:09 PM
LiquidBlue's Avatar
Transmission: MD8
what part of the cc? im not seeing an obvious break off point
micktroup2
Sep 27, 2012 02:37 PM
Ian'sTA
Jan 19, 2007 06:18 PM
CamaroKid89RS
Mar 3, 2005 04:08 PM
Doward
May 6, 2003 10:24 AM
