91 firebird has no power at all
Old Aug 19, 2019 | 01:27 PM
stickychinsac's Avatar
Car: 91 Bird
Engine: 350 carb
Axle/Gears: Strange 12 bolt, 4.11
Ok so 2 weeks ago I swapped to long tube headers. A mistake was made during installation and the starter wire welded to the header and melted the battery wires. I replaced the pos and neg battery cables and started the car, everything was fine. I finished tightening down the power to the starter which was only hand tight to test it and when I tried to start it the engine turned over for half a second and then everything went black. No gauges, no lights, nothing has power. I can't find any wires that look bad, I can't find anything. Any ideas where to look? I'm at a complete loss.
Old Aug 19, 2019 | 01:36 PM
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Re: 91 firebird has no power at all
Fusible link?
Old Aug 19, 2019 | 01:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
they are connected to the starter positive cable.
Old Aug 19, 2019 | 02:38 PM
Car: 91 Bird
Engine: 350 carb
So would that cut power to everything in the car? I see there are a couple fusable links off the starter. How can I test them? They are locked in a black plastic block of some kind so visual seems out of the question. There's another fusable link going to a junction post by the battery, there's power there, I tested that before I hooked up the starter wire but I don't know what all gets power from there. My fan and msd box I believe but there's several small wires.
Old Aug 20, 2019 | 01:01 PM
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Yes, a bad fusible link will kill power to the entire car, just as you described.
I'm not well versed on testing them, but I would imagine a resistance or continuity check across the link would tell you whether it was blown.
Someone else may be able to provide more detail.
Old Aug 20, 2019 | 01:07 PM
Engine: Lb9
Transmission: M20
the easiest and safest way is to disconnect the battery and test them with a ohm meter. Start from the positive lug of the starter and pierce the sheathing of the wire. Making a small hole like with a safety pin. Damaging the insulation will eventually cause the copper to get wet and corrode.
Old Aug 21, 2019 | 05:52 PM
Car: 91 Bird
Engine: 350 carb
​​​​​​I tested everything and I got power through them but it was drawing down when some were connected. I ended up finding a broken ground and a poor ground. I put eyes on them before and somehow overlooked the issue. Not a total loss, I learned more about the way the car is wired so cleaning it up this winter will go a little smoother.
82ztwenty8guy
Jul 18, 2014 12:25 PM
88Camaro1993
Jan 2, 2014 01:10 AM
-LateNite89-
Nov 5, 2012 09:43 PM
ls six
Dec 28, 2008 03:35 PM
UDAMON
Jun 5, 2005 10:48 AM
