My turn single nightmare. Any help would be great.
Old Aug 22, 2019 | 02:47 PM
flipny666's Avatar
Hey guys I going to keep it kinda short. But here's what I am working with. When I turned my light switch on some of My gages would drop to 0 and my left turn signal on the cluster would light up. When I turn the left blinker on with the head lights on the gages would jump up and down. So frist thing I did check all the lights and fuses. Then changed the head light switch. Still did the same thing. Got pissed and put the car away for winter. Got it out for summer and said f**k it and put an led cluster in thinking there might be a short in that. Well I was wrong again. Gave it a few weeks then changed out the turn signal stalk. Still not working. Then just made it worse by putting led taillights in. So right now when I turn the turn on left or right it doesn't matter it just stay solid. But whe. I put the hazards on they flash. The 2 flasher relays are for the led setup. All the bulbs work. Also when the car is off with the key out the left flasher stays on solid. Any help thanks .
Old Aug 22, 2019 | 05:31 PM
Schurkey's Avatar
Re: My turn single nightmare. Any help would be great.
Instrument cluster not properly grounded?
Old Aug 22, 2019 | 05:59 PM
flipny666's Avatar
The cluster works now but I did check all the grounds.
J0hn_J0hn08
Nov 7, 2011 02:28 PM
rubyred88
Jun 27, 2011 03:02 PM
tpi305
Mar 13, 2009 12:10 AM
Yellow87Cam
Jan 2, 2007 06:36 PM
redcamz
Nov 26, 2005 08:47 PM
