turn signal indicator
Car: 88IROC Vert
Engine: ZZ383
...the right little green arrow just stopped blinking. Left one works fine and all outside blinkers work. Anyone have bulb specs for that green arrow?...or ideas on what else it could be? thanks Car is an 88 IROC.
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: turn signal indicator
Do the outside right signals work? If so it could just be a bad bulb in the gauge cluster. If they don't work, you probably have a bad bulb somewhere. But, from what I remember, a bad bulb makes them stay on instead of blink.
Sorry, Just reread it, the outside lights do work, so I assume it is the light in the cluster.
MikkoV
Sep 9, 2015 04:25 PM
