turn signal light blub question????
Old Nov 19, 2005 | 01:04 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Transmission: 5 speed
ever since i change my instrustment cluster to 145mph, my left turn signal light on the cluster will stop blinking after awhile, but it will work again the next day, i don't think is the bulb. any help would be appreciated, thank you.
Old Nov 19, 2005 | 05:33 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
look for a circuit breaker in the circuit if there is one there is probably a short somewhere and the wire is getting to hot.
did you put new bulbs in the cluster when you changed it?
Old Nov 24, 2005 | 02:52 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
hey thanks wiseman, i did not change all the blubs, just a few of them and i know i did not change the left turn signal blub. how would you check the circuit itself? thanks again.
Old Nov 24, 2005 | 03:13 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
It could be the turn signal flasher. The one in my '84 Trans Am went bad. Maybe 1984 was a bad year for turn signal flashers!
It would flash and then stop and the turn signal would just stay lit in whichever direction I was turning. If I reached under the dash and gave the flasher unit a tap it would work again a few times before the who process started again.
Old Nov 24, 2005 | 06:28 PM
Car: 82 z28
Transmission: TH350
sorry im not really good at explaining how to test things like that a wiring diagram is a must and knowing how to read them is good and a test light sorry thats pretty much all the help i can give without looking at it
Old Nov 25, 2005 | 10:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This is a bit after the fact, but if the original cluster functioned properly, your best bet is to swap only the speedo head.
JamesC
Old Nov 26, 2005 | 06:17 PM
Car: 82 z28
Transmission: TH350
whats wrong with the spedo? and thats not how you fix things by just guessing its a part and replacing it thats how you waste time and money you need to find exactely where the problem is and replace or fix that area
Old Nov 26, 2005 | 08:47 PM
JamesC's Avatar
If the original cluster functioned properly and the new one doesn't, reason would dictate that the new cluster is at fault. If the new cluster's speedo works and the original cluster functioned as designed, put the new speedo into the orginal cluster and ride off into the sun set. (I've sold 8 or 10 clusters and my advice was always to swap the speedo head into the original working cluster--just seems to elevate problems as described.)
JamesC
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
