1989 Trans Am GTA, lights problem.
Old Oct 15, 2019 | 01:11 AM
Oliver Tali's Avatar
Hello!
I have a problem with the turnsignals, allready searched the forum and the internet.
Also im New to the third gen, but ran into problems right away.
The problem is, if i push the turnsignal stalk to the left, it burns the fuse, then sometimes burns the brake light fuse too.
If i change the fuse the flasher stay lit, if i push the brake pedal, brake lights will come on with both of the back turnsignals on.
Changed allready flasher, cheked all the grounds, at least i belive. Repaired some wires witch had craked insulation.
Now im out of variant to chek.
The stalk itself, if you push it down, it clicks at the bottom of the movement, if you push it up it clicks AS soon AS you move it up.
Ghettobird52
Nov 15, 2016 11:01 PM
Yoseph Jakob
Aug 25, 2011 06:51 AM
Spiers
Mar 14, 2006 05:08 PM
91ThunderRS
Jul 3, 2002 11:46 PM
