Rear defroster fuse
Old Oct 20, 2019 | 09:21 AM
Hamburger's Avatar
Car: 1991 TA GTA WS6
Rear defroster fuse
On the 91 fuse panel, does the same 30A fuse work the power lumbar on the seats and the rear defroster? Fuse 12 I think? Switch is working. Connectors are on the struts ok, timer stays on about 15 minutes, but the defroster not working. Time to get out the old test light. Previous owner removed the tint film from the rear window (Don't now why) . Hopefully he did not damage the grid. It must be a Maryland idiotic law you can't tint the windows. He said he spent hours removing the film which made me worry since I can do it in 5 minutes with a heat gun on the outside.
Old Oct 20, 2019 | 01:32 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Rear defroster fuse
Probably the defroster elements.PO probably did the deed when he removed the tint. The switch has a big purple wire for power though, not sure if its sharing the circuit with anything.Its a big power robber.
Time
Mar 24, 2006 09:56 AM
bac67
Jul 17, 2005 01:32 PM
88firebird
May 26, 2005 05:06 PM
GTA88
Nov 16, 2000 03:34 PM
