Argh ! Acc'y fuse blowing again !!
Old Nov 12, 2000 | 12:10 PM
GTA88's Avatar
Hi,
I just posted about this fuse a few days ago. I took out the lighter and the fuse went in and did not blow, and I thought all was well.
But..... the same fuse blew again. The fuse lasts for about 10 minutes of easy driving. There's nothing specific I do that blows it. I don't use any of the parts that it goes to, it just blows out after about 5 or 10 minutes of driving.
So, my q for today is this : How do I get the lighter socket to come out? I have the lighter out already. Can the socket itself be corroded and blowing out the fuse ? BTW, I can use the lighter, and that will NOT blow the fuse .
But I'd still like to remove the lighter socket, or disconnect the wires to the socket, just to rule it out as the cause of the short. Do I need to remove the console lid ??
Old Nov 14, 2000 | 07:59 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Remove the panel it is mounted in & unplug the connector on the rear of the socket.
Tim
Old Nov 14, 2000 | 04:54 PM
GTA88's Avatar
Old Nov 15, 2000 | 10:54 PM
Chris Luongo's Avatar
Do you have an aftermarket car radio? That would be a prime spot to check for an exposed wire. The constant power feed to the radio is on the same circuit as the lighter and dome light.
Old Nov 16, 2000 | 03:34 PM
GTA88's Avatar
The radio looks like an original, although there is a wire which loops out from under the radio 'console' by the driver's right foot ! Another thing : even though the owner's manual says the radio is on the dome light fuse, the radio never gets knocked out when this fuse blows !!
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
usafirebird
Sep 29, 2015 11:58 PM
