Junction block
Old Nov 2, 2019 | 02:16 PM
Speeddemon1's Avatar
Junction block
Hi, i have my bird running again ,and now i have a question there is a fuse with wire burnd,
at the junction block i want to repair iT with a new fuse ,but i dont no how hige THE amp is ,
Where is this wire from?
Old Nov 2, 2019 | 02:31 PM
Re: Junction block
Looks like it had a fusible link on it at one time.
You should put it back the same way. NOT with a fuse; that will introduce more points of potential failure.
A fusible link should be about 3 - 4 gauges smaller than the wire it protects. That's really what it's there for, is to protect the wire. That wire looks like 10 or 12 gauge; the metric sizes are 5mm and 3mm respectively. If it's 10 gauge or 5mm, the correct FL will be colored "rust" (this is the most common); if it's 12 gauge or 3mm the FL needs to be light blue.
Old Nov 2, 2019 | 02:42 PM
Re: Junction block
Hi thank you for THE info ,Yes there was a fuse link on it,
i want to replace iT but i dont know with what kind of fuse link ,🤔
Old Nov 2, 2019 | 02:45 PM
Re: Junction block
Go to the parts store and look in the Electrical section. Look at the red wire it goes on first and find its size, so you know which color/size FL to get.
Old Nov 2, 2019 | 03:03 PM
Re: Junction block
Hi thank you ,i will do that
paulmoore
Car Audio
Oct 29, 2023 11:49 AM
wwisema1
Oct 9, 2019 07:08 AM
sharlimar
Nov 11, 2015 08:16 PM
ryguy85
Jul 22, 2004 08:46 PM
Iroc n roll
Mar 17, 2003 08:08 PM
