Terminating circuits
Old Nov 5, 2019 | 09:36 AM
MicksIroc's Avatar
Im rewiring my engine bay. Is there a right or wrong way to terminate unused circuits? For example Fog light relay and circuit. I no longer need it or want it and the less crusty wiring the better. Can I just cut off the relay and terminate the ends (not what I would like) or fish back to the C100 and remove there? Also have no need for the fuel pump, maf relays by the booster.
Old Nov 5, 2019 | 09:46 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Terminating circuits
I would suggest removing all the wires all the way to the connector, then remove the terminal from the connector with a small screw driver so there is no risk of the tape, or what ever you use, to come lose and short out to ground.
Old Nov 6, 2019 | 01:43 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I've used this product for many years.
https://plastidip.com/our-products/liquid-tape/
My first choice would be what scooter suggests. But dipping the ends in a couple of coats of this would probably do the trick.
malcom2073
Apr 10, 2011 01:19 PM
jayk2k3
Aug 8, 2006 06:52 PM
acescarrsRS
Mar 16, 2004 11:19 AM
8T8IROC
Dec 8, 2003 12:17 PM
scottmoyer
Jul 16, 2003 05:03 PM
