Wiring a 1984 iRock Camaro to have a 1992 instrument panel in it
I have a 1984 Camaro I rock with a V-8 I’m trying to put the instrument panel out of a 1992 Camaro RS with a V6. I was wondering on how I could wire it in
Re: Wiring a 1984 iRock Camaro to have a 1992 instrument panel in it
Your first major problem would be that your 1984 cable operated speedometer setup car is not gonna drive the 1992 electronic speedometer dash without modifications
Second major problem , the six cylinder tach is different than the eight cylinder tach , and will not read the correct RPMs when connected to an incorrect engine without modifications
Minor problem will be that the V6 VS V8 oil pressure gauge is scaled differently , so that won't read correctly without a V6 oil pressure sending unit
PS , you have an "IROC" and NOT an "I Rock" !!!! ... IROC was the "International Race Of Champions" , and it has yet to be determined whether , in fact , you rock or not
... Thread
