instrument panel
Old Mar 26, 2008 | 10:58 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
instrument panel
well i have an 86 camaro and the instrument panel has the 85 mph gauge and no tac, and i was just wondering if i could take the instrument panel out of my 88 which has the 115 mph gauge and a tac and put it onto the 86.
ik it wont work all at once but is it still possable if i hook up a wire or two? and will the trans and engine even go faster then 85 without being hurt?
Old Mar 27, 2008 | 01:17 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: instrument panel
It should work fine, assuming a few things. If your engine is a V8, you'll need a V8 tach, or if its a V6, a V6 tach. If your car currently has the warning lights for temp and oil pressure, instead of gauges, I'm pretty sure you'll need to swap in the correct sending units. They're cheap and easy to do, so that's not a big deal. There is a tech article on swapping in an IROC 145mph cluster, the procedure is the same:
https://www.thirdgen.org/gauges
Old Mar 27, 2008 | 01:24 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
IT works. Atleast it did for me. Except I didn't plug the cable back in tight enough and had to do it all over again. D!@# it.
Old Mar 27, 2008 | 02:02 AM
DARKmj16's Avatar
Engine: 305 tbi
ok cool, still got a few questios tho 1 is i just reliezed the 86 r digital, so i need to replace the sendings units, but what bout the actucal censor and wiring? and is do i already have a tach hook up? or do i need to buy something tp put onto the motor? the article did help me but those r the 2 things am unsure of right now and seeing as how the 86 is my daily driver i dont/cant have it not working
Old Mar 27, 2008 | 03:21 AM
OS3Fleming's Avatar
Engine: 357 SBC
Well you didn't say Digital, Thats different then what I have done. Search the site ask some questions. you know.
Old Mar 27, 2008 | 03:52 AM
DARKmj16's Avatar
Engine: 305 tbi
sorry i shold of mention it earlier, but something tells me i wont be very succesful in my searches, but you'll never now till you try huh? well off to the wonderful wizard of serches, lalala...
Old Mar 27, 2008 | 04:13 AM
DARKmj16's Avatar
Engine: 305 tbi
ok im back, and as i figured i couldnt find anything to help me, but i have discovered an intersting thing, whne i said digital guages everyone assumes that its full digital, but its not...hmm how do i discribe it...
ok now that i have found something useful from the searches you see how the 140mph guage is, well on my 86 it goes to 85, now where the tach is that is the fuel guage, and the 3 little ones in the middle, those are there bout those are the digital ones, make sense? i mean they have the name/symbol, the numbers, everything like a regular guage, but instead of a needle, its lights...i should have a pic of it soon to show everyone what im talking bout
Old Mar 27, 2008 | 05:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
With the exception of the Berly, there's nothing digital about Camaro clusters (82-89 the speedo head is mechanical, the gauges electric). The swap Ward and OS3 mention should work fine.
JamesC
Old Mar 27, 2008 | 03:46 PM
DARKmj16's Avatar
Engine: 305 tbi
ok thank you james c, but hopoefully one last question, doing this swap, will the 86 actually be able to go up to 115mph? with out anyhting messing up, i think it would be ok, but its always good to get second options. and one last thing, do i need to buy a tach setup to hook up to the motor for the tach on the cluster to work? thanks for the help eveyrone
Old Mar 27, 2008 | 05:40 PM
JamesC's Avatar
[QUOTE=DARKmj16;3694503will the 86 actually be able to go up to 115mph? with out anyhting messing up... and one last thing, do i need to buy a tach setup to hook up to the motor for the tach on the cluster to work? thanks for the help eveyrone[/QUOTE]
If your car will do 115 or 145, the speedo will read correctly. Check Ward's link above for the tach info.
JamesC
Old Mar 27, 2008 | 09:45 PM
DARKmj16's Avatar
Engine: 305 tbi
ok im stupid , thanks james c, i do believe thats all for this topic, thanks every1
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
