Arap chip
Old Feb 14, 2020 | 03:12 PM
Maito's Avatar
Car: Trans am 87
Engine: 350 tpi
Arap chip
Hej har just bytt till eprom med arap chip vill bli av med kallstarts injector 9e. Å det gick bra men det som hände var att fläkten körs hela tiden från det jag startar bilen någon som vet vad det är för fel den gjorde inte så tidigare med orginal chip. Mvh micke
Old Feb 14, 2020 | 04:17 PM
Drew's Avatar
Re: Arap chip
Hmm... Swedish.
Hi just switched to eprom with arap chip want to get rid of cold start injector 9e. Oh it went well but what happened was that the fan runs all the time from the time I start the car someone who knows what is wrong it did not do so earlier with the original chip. Mvh micke
Old Feb 14, 2020 | 05:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Arap chip
There is a flag you have to check or uncheck to use arap in an fbody
Det finns en flagga som du måste kontrollera eller avmarkera för att använda arap i en fbody
Old Feb 15, 2020 | 02:28 AM
Maito's Avatar
Car: Trans am 87
Engine: 350 tpi
Re: Arap chip
What flag in the program where you burn the chip?
Old Feb 15, 2020 | 11:24 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Arap chip
What are you using to tune and mod the bin files?
i think its called cooling fan n/o req input. Check this box
Old Feb 15, 2020 | 04:45 PM
Maito's Avatar
Car: Trans am 87
Engine: 350 tpi
Re: Arap chip
Can't answer it when I bought it from someone who programmed that year me. But he says he programs the epromen himself after 89 trans am 100% original
Old Feb 15, 2020 | 05:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Arap chip
Well you cant fix it without programming it correctly
Old Feb 16, 2020 | 02:37 AM
Maito's Avatar
Car: Trans am 87
Engine: 350 tpi
Re: Arap chip
Okay, contact him who programmed it again. But one question it may not have to do with water temperature sensor fan control? Have ordered one but haven't received it yet
fatbob
Jul 2, 2007 07:09 PM
smithtc
Mar 20, 2005 01:29 AM
slayer2000
Mar 6, 2002 04:00 PM
