Trying to Read Hypertech chip
Old Mar 16, 2005 | 08:28 PM
smithtc's Avatar
Burned my 1st chip
Helped me solve a No-Start condition by turning off VATS. Payed for itself its first use.
Anyway....I used an ARAP bin to get my car running again. Car had a Hypertech chip in it. I would like to read this chip to compare to the ARAP. I'm having problems getting this chip read. It FAILED every time I clicked on Verify Chip With Buffer...and I couldn't get it read. Its an 1989 MAF 350 w/ and Automatic Hypertech chip. Does it have some kind of protection so I can't read its programming? Or, what's the proper way to read it? Using Flash & Burn BTW
thanks
Old Mar 17, 2005 | 05:07 PM
-js-'s Avatar
Car: 1986 vette/91 RS Vert
Engine: zz4 l98/Tbi 305
Transmission: 700r4/ 5 speed
You could try using moates ecm852 to download it over the obd connection. http://www.moates.net/zips/ECM852.ZIP
Old Mar 17, 2005 | 08:31 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I did not have a problem reading the 89 hypertech 350 tpi chip, it was a 27c256 in stead of the 27c128 that came in the stock memcal
Old Mar 17, 2005 | 09:39 PM
smithtc's Avatar
Appreciate the help.
Got it to work. Read it as the 128 (read only) file. Wouldn't verify still, but I had to save it as a .bin file. Then I was able to bring it in to my TunerPro. Comparing to the ARAP bin now.
I'm learning
Old Mar 18, 2005 | 01:38 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
lol
I'll save u the comaprison.
Fan temps changed like 30 deg less than stock and timing in the 100kpa table row by like 10 degrees +.
later
Jeremy
Old Mar 18, 2005 | 05:52 PM
smithtc's Avatar
OK...
I'm looking at a lot of this stuff in TunerPro and just trying to figure it out....some is apparent, some is not.
Comparing the Hyperchip to the ARAP bin
Flags 1st...
1st and 2nd Air flow Mode Word were identical
On the 3rd Air flow Mode Word:
Hyper chip has the Bit 7, Bit 3, and Reset checked
ARAP has the BPW and Reset checked
On the 4th Air Flow Mode Word:
Hyper has the FANNO, CCPIN, and 4thGr checked
ARAP only has the CCPIN checked.
What's the differences there?
Better yet...where can I get a detailed explanation of all these items (constants, flags, tables) in TunerPro? I looked in the Help, but maybe I missed it...
Old Mar 20, 2005 | 01:29 AM
Z69's Avatar
Z69
Go to Craigs' site or DIY-EFI.org and look for the arap.hac
Search in the hac on the address for the table etc you want and see when it's used etc....
Do some searches on the 7165, 6E, 32x.....
andy74
Sep 3, 2015 08:41 AM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
