What are these wires/connectors?
Old Feb 26, 2020 | 04:10 PM
CoreyManCan's Avatar
Car: 1982 Z28 Camaro
Engine: 5.7L V8
Transmission: TH350
1982 Camaro, engine is a non original carbureted 350. I’m assuming one of them is for the horn as the wiring to the actual horn was cut off for some reason. I’m also having trouble finding the wiring for the temp sensor. It would be really appreciated if someone could identify these for me.
Old Feb 26, 2020 | 04:17 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: What are these wires/connectors?
The two wire plug in the first pic looks like the AC compressor plug if I recall correctly.
Old Feb 26, 2020 | 04:18 PM
Engine: 5.7L V8
Transmission: TH350
Yeah the air condition wiring is all in the car just not hooked up at all. Do you have any idea what that cut green wire is on the first picture?
Old Feb 26, 2020 | 05:59 PM
Drew's Avatar
Green wire could be part of the AC wiring, the temp gauge sender (most likely), or another circuit. Hard to tell without tracing it back, or the connector. You could jumper it to ground with a fused jumper wire and see if the temp gauge pegs out. The ones up front look like the cruise control transducer, but it's been 2 years since I was under the hood of an early thirdgen.
IROC-BOB86
Oct 17, 2019 08:16 PM
snake 309
Mar 14, 2017 05:47 AM
rjt76
Jan 21, 2006 02:16 PM
pasky
Jul 1, 2003 11:57 PM
