Tach needle "backwards"
Old Mar 9, 2020 | 12:20 PM
BullsLawDan's Avatar
Hey guys, so my tach needle (86 z28) points straight up when the car is off, as opposed to down where zero is. When I start the car, the "back" of the needle points right where my idle would be, 1000-1500. Front of the needle is pointing in the opposite direction.
It's turning in the right direction when I hit the gas, and appears to be turning in relatively the right motion for how much I hit it.
Is it possible someone had the gauges out and stuck the tach needle on backwards? Is this something I could fix by opening up the cluster, pulling the needle off, and reversing it? Is the polarity backwards on something behind the cluster?
Thanks.
Old Mar 9, 2020 | 01:24 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: Tach needle "backwards"
Instrument pointers usually go on ONE way, if it was positioned incorrectly during re-assembly, it could be positioned correctly by removing the tach and having the pointer positioned in the correct orientation. If this is something you did not screw up yerself, take it back to where it was screwed up, and have them fix it.
Otherwise, yes, the cluster comes out and the tach pointer can be removed and repositioned.
Old Mar 9, 2020 | 05:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Instead of ruining it any more than it is, take it to an instrument repair shop.
The tachometer is easily removed from the carrier (unplugs) once the bezel/lens/reflector is removed.
Old Mar 9, 2020 | 08:45 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Are you sure about that ???
That hing isn't like the stepper motors in the newer clusters. I know I've pulled the needle off a thirdgen Tachometer before and for some reason I seem to remember that being a bad idea.
Old Mar 9, 2020 | 10:37 PM
427seven's Avatar
[QUOTE=John in RI;6358524]Are you sure about that ???
Done it many times, but never in a Camaro. I have several Firebird clusters both cable and electronic laying around. The needle just pulls straight off the end of the pin, friction fit. I see now that this is an 86 Camaro, and - unlike the firebirds - I think they had cables though 87. If it's not electronic, I gotta say I dunno….
Old Mar 10, 2020 | 10:59 AM
I do have a 140mph speedo, if that helps determine what my cluster and tach setup is. It's my understanding those starting showing up in Z28's late in the 86 model year.
dame28
Oct 6, 2010 08:51 PM
Diskonectid1
May 19, 2010 06:46 PM
86birdv6
Mar 16, 2004 08:56 PM
bcm90iroc
Nov 3, 2003 12:20 AM
breathment
Mar 6, 2002 03:58 PM
