Code 54
Old May 10, 2020 | 05:10 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Transmission: 4 Speed automatic
Code 54
Hi, I have a 1986 firebird with a fuel injected 2.8L v6. It was giving me the service engine soon light and I did the paperclip trick to get in return a code 54. I've looked through the other forums but can't find anything that works. I replaced the fuse on the passenger side hanger and sprayed the relay switch with electrical contact cleaner, which made the light turn off for a day. When I turn the key to the run position, I can hear two distinct clicks, (i'm assuming from the relay switch), but that's all, until I turn the key back to the off position, when I hear something that sounds like a spraying sound. The "spraying" stops after two seconds. I tried sticking a mulitimeter in some of the switches, but couldn't get anything to read. I'm assuming that was user error. The car runs great, just takes a little longer than I would like to start. Any suggestions?
Old May 10, 2020 | 05:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 54
Voltage at the ecm b2 while running ?
https://www.thirdgen.org/forums/dfi-...l#&gid=1&pid=1
Old May 10, 2020 | 05:18 PM
Engine: Lb9
Transmission: M20
Re: Code 54
The 2 second noise is fuel pump prime
Old May 10, 2020 | 05:25 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Code 54
Do I test the voltage with it disconnected from the switch? Are you measuring it in AC?
Old May 10, 2020 | 05:33 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Code 54
Scratch that, well digging around I think I found the problem. Where does this go?
Old May 10, 2020 | 05:45 PM
Engine: Lb9
Transmission: M20
Re: Code 54
That’s the ac compressor plug. Has nothing to do with low fuel pump voltage.
your car is dc. Measure the power at the ecm while the car is running.
Old May 10, 2020 | 05:49 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Code 54
Forgive me for asking but where is the ecm?
Old May 10, 2020 | 05:51 PM
Engine: Lb9
Transmission: M20
Re: Code 54
Under the dash on the passenger side of the car.
Old May 10, 2020 | 06:01 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Code 54
Down here?
Old May 10, 2020 | 06:04 PM
Engine: Lb9
Transmission: M20
Re: Code 54
It’s in a bracket hooked to the dash frame below the speaker. Accessible from under the dash.
Old May 10, 2020 | 06:12 PM
Engine: Lb9
Transmission: M20
Re: Code 54
Old May 10, 2020 | 06:42 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Code 54
It reads 14.71 at the ecm
Old May 10, 2020 | 06:46 PM
Engine: Lb9
Transmission: M20
Re: Code 54
Then if your still getting the code 54 could be a bad ecm . Or a intermittent power issue.
splice, ops .
Old May 10, 2020 | 07:03 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Code 54
I played around with the fuse on the passenger side wall some more, that seemed to have fixed it... When I took the ecm out I found yet another disconnected wire. Know where this one goes?
Thank you for your help
Old May 11, 2020 | 03:52 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Code 54
These schematics are from the 86 Shop Manual and for the 2.8 MPFI:
Hope they help !
Old May 12, 2020 | 11:40 AM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Code 54
It certainly did, thanks!
SHELL929
Nov 18, 2015 01:51 PM
Tyler0413
Jun 15, 2011 12:26 AM
black88ta
Feb 14, 2004 10:32 AM
rscamaro91
Mar 16, 2001 11:22 PM
88 IROC BOB
Oct 17, 2000 07:44 AM
