Mystery wires
Old May 11, 2020 | 08:47 AM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Transmission: 4 Speed automatic
Mystery wires
Any idea where these go? Found them disconnected on a 86 firebird fuel injected v6.
Old May 11, 2020 | 02:36 PM
cmiller2014's Avatar
Car: 1991 Camaro Z28
Engine: 6.0 LS
Axle/Gears: 9" Rear w/ 3.70 TruTrac
Re: Mystery wires
Is your car a manual? Looks like a clutch safety switch if you're referring to the purple and yellow wires.
Old May 11, 2020 | 02:46 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
I am talking about the purple and yellow ones, it's an automatic
Old May 11, 2020 | 02:53 PM
Engine: 6.0 LS
Re: Mystery wires
I’m pretty sure it’s the neutral safety switch on an automatic
Old May 11, 2020 | 02:58 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
Do you know where they plug into? Here's a better picture:
Mystery wires
It's not these
There's another set of purple and yellow wires already plugged into the ecm but it's not those
Old May 11, 2020 | 04:34 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Re: Mystery wires
This thread might be of use... https://www.thirdgen.org/forums/elec...ring-help.html
Old May 12, 2020 | 10:57 AM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
I believe his wires were on the opposite side of the car, I'm under the dash on the passenger side. Sorry for any confusion
Old May 12, 2020 | 12:54 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Re: Mystery wires
Can you trace them to the ECM ?
Old May 12, 2020 | 12:59 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
I'm at the unplugged end that's by the ecm right now, I can't see where it plugs into or trace it anywhere
Old May 12, 2020 | 01:00 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Re: Mystery wires
If you have a multi-meter, can you see if it's the same wires that are plugged into the ECM (look for same color and thickness) ?
Old May 12, 2020 | 01:07 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
They are the same color and thickness, the multimeter gave me the same voltage on both. The end that's in the ecm is in the yellow box
Purple wire have me 0.4 volts and yellow gave me 0.1
Old May 12, 2020 | 01:27 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Re: Mystery wires
OK sorry. When using continuity mode, does the purple wire that connects to the yellow box (does it say buffer on it?) have continuity with the purple wire in the unknown plug? Same with the yellow?
If so, sounds like they would be connected to the VSS speed sensor on your transmission. Reference this post https://www.thirdgen.org/forums/elec...arb-350-a.html
Old May 12, 2020 | 01:34 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
I am getting continuity, and the yellow box does say buffer on it
Old May 12, 2020 | 01:43 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
So where is it supposed to be going to/coming from from the buffer box? I tried to pull the unplugged wire end out but it is attached to the rest of the wires I'm assuming from the factory
Old May 12, 2020 | 01:44 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Re: Mystery wires
OK then the wires would go to a sensor on your transmission. A thread about its operation can be found here... https://www.thirdgen.org/forums/elec...ss-buffer.html Does your speedo work?
Old May 12, 2020 | 01:50 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
The speedometer works (last I knew) I don't think there's enough length on this wire to get it to the transmission. I didn't know about this wire being loose until I went to test some voltage at the ecm, so it's possible I pulled it out, but it seems hard to believe that it would have unclipped itself
Old May 12, 2020 | 01:54 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Re: Mystery wires
If the speedometer works then I wouldn't worry about it.
Old May 12, 2020 | 02:11 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Mystery wires
Ok, thank you for your help.
zrafferty
Jul 8, 2020 05:35 PM
Ron U.S.M.C.
Aftermarket Product Review
Feb 14, 2012 04:50 PM
Red91Bird
Aug 24, 2001 01:21 AM
