Fuel Gauge Reads Full all the time
Old Jun 4, 2020 | 12:11 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Greetings,
Does anybody know some troubleshooting short cuts / tips / links / diagrams, etc. to find out why my fuel gauge is reading full all the time. 1989 Firebird with stock tank and sending unit. Any and all information will be greatly appreciated.
Ciao~
BH
Old Jun 4, 2020 | 02:21 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Fuel Gauge Reads Full all the time
In general, GM fuel senders measure 0-ohms when the tank is empty and 90-ohms when full.
You can measure this resistance at the fuel tank connector to see if it's the gauge or the sender. Doing it this way requires you to measure the resistance with the tank partially empty.
Or you can perform the test per the attachment (Chevy-Pontiac should be the same for both).
Old Jun 4, 2020 | 05:27 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Thank you for the information, let me ask you this question:
Before I ask, I have not read the Service Manual PDF's that you posted.
If I remove the connector for the fuel sender and pump (located just above the read diff) should the fuel gauge read empty?
Ok I am bit confused, how does the pink wire get to the dash. Is C208 located behind the back seat and is some how connected to connector C313 which is above the diff? I dont see any wires leaving the tank going to dash.
Thank you for your time.
BH
BH
Last edited by bluegoose; Jun 4, 2020 at 05:44 PM. Reason: adding question about pink wire and connector C208
Old Jun 4, 2020 | 08:28 PM
Unplug = full
Short to ground = empty
See my signature
tmork454
Apr 24, 2014 09:47 PM
FireDemonSiC
Sep 21, 2011 11:25 PM
Wild_child
Apr 10, 2011 09:27 PM
formula forever
Apr 5, 2007 02:43 PM
RICHRAD
Mar 7, 2001 06:41 AM
