92 camaro RS 3.1 5SPD
Old Jul 15, 2020 | 10:18 AM
motionwannabe's Avatar
Hi everyone!! I'm working on a 92 Camaro Rs 3.1 5SPD this car is a real pain in the butt!!! We brought it in it wouldnt start and stay running. Turned out distributor was rusted so badly inside that it literally rotted the pickup teeth off the rotor shaft under the cap. We replaced that. car starts but runs horribly. We are ordering an ecm for it as well now. But the problem we have now is it has no headlights markers , dash lamps, high beams,dome light, courtesy lights NONE OF IT WORKS!! Replaced the switch still nothing. Wipers , tail lights, turn signals and reverse lights work. Cigarette lighter doesnt work either. I went through the fuses. None are blown and no wires chewed anywhere. ANY HELP WOULD BE GREATLY APPRECIATED!!!!!! THANK YOU!!
Old Jul 15, 2020 | 04:58 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 92 camaro RS 3.1 5SPD
Two words come to mind here , search these two words and you'll have you answer to your electrical problems ;
Fusible links
​​​​​​​ Fix that first , and then go after the poor running situation .....
91firebird3.1
May 23, 2013 07:58 AM
king_monkey
Dec 26, 2002 02:57 AM
