Looking for low-temp cooling fan switch. '84 Z28
Just as the title says. I've been looking for a lower-temp fan switch for a while now, probably on at 200 degrees. I'd like it to have the OE connector so I don't have to hack up the wiring, but every switch I've found either has a different connector or is the OE temp. If anyone knows where I can get the one I want, it'd be much appreciated.
Car: 1991 Camaro RS
Engine: LO3 TBI VORTEC
Re: Looking for low-temp cooling fan switch. '84 Z28
I bought this one,
it comes on a little before the 180 thermostat opens and pretty much stays on after that, I haven't driven that much with it.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
This one lasted 5 times longer than any other fan switch I've used. Used to gat them from Summit but looks like they don't have any right now
