Found a small button next to fuse box; no idea what it does.
Old Aug 6, 2020 | 05:21 PM
ElBarto's Avatar
So I just picked up an 1987 Camaro IROC Z28. Everything seems to be original except when I was fixing a few things I found a small push button switch wired in next to the fuse box. It appears to be a momentary press sort of button. It appears one side is grounded and the other is tapped into a solid white wire under the dash. I've tried pushing the button with the car on and it with it off and nothing happens that I can tell (no ejection seat unfortunately).
Any one have any thoughts on what it is?
Old Aug 6, 2020 | 05:27 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Re: Found a small button next to fuse box; no idea what it does.
I had one like this under my dash in the same spot. Mine was disconnected, I had assumed it was part of a kill switch...
Couldn't really think of another reason for it.
Old Aug 6, 2020 | 06:08 PM
DON'T PUSH IT!!!! The antimatter might come land on your driveway and annihilate all the matter, and the entire known universe might implode into a tiny mass smaller than a quark, but we'll never even know it because we'll be that small too. You don't want to be THAT GUY, do you???
Seriously...
Looks like typical PO bullplop. Trace the wires, see what it goes to, maybe you can get inside the idiot's head just long enough to figure out what s/he had in mind (I use the word VERY loosely). Then very carefully remove EVERY TRACE of it and all its wires, directly to the trash can; and restore to its former glory whatever factory wiring s/he hacked up, with solder and heatshrink.
Old Aug 6, 2020 | 09:25 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Seriously...
LOL! I was about to say it fires the ejection seat, but you outdid me!
Old Aug 6, 2020 | 09:31 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
For charging up the turboencabulator.
Old Aug 7, 2020 | 07:35 AM
Drew's Avatar
Usually it's an alarm valet/programming/override switch.
Old Aug 7, 2020 | 11:10 AM
GeneralDisorder's Avatar
It's an aftermarket alarm system control button. It's for programming remotes and such.
GD
Wickydooda
Jul 21, 2020 03:37 PM
Michigan419
Oct 22, 2019 08:57 AM
tbeyer
Sep 11, 2019 07:13 PM
xsupermann69x
Jun 4, 2007 11:01 PM
