Rear hatch conversion
Old Sep 30, 2020 | 07:01 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Does anyone have experience converting the rear electronic hatch pull down assembly to a standard key operated release? The hatch assemblies are getting harder and harder to find and mine is giving me fits. I have a late model 91 RS.
Old Oct 27, 2020 | 03:57 PM
Outkast Actual's Avatar
Car: 1988 Camaro RS
Engine: 383 Stroker
Transmission: TH400 3 Speed Auto
Axle/Gears: 373 Richmond
Re: Rear hatch conversion
Hopefully someone chimes in on this... I'm interested in this as well.
Old Nov 2, 2020 | 01:57 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
PULL !
I see one on ebaY as I am writing this.
Seller has a 99% positive rating.
Happy Racing!
Normal Cars: Refuling Takes Seconds.
Electric Cars: Recharging Takes HOURS, Which One Makes More Sense?, You Do The Math
Old Nov 2, 2020 | 06:44 PM
MNformula350's Avatar
One of the best things I ever did to my Formula was chuck that unreliable trunk pull down in the garbage.
It is relatively easy, I removed the entire latch assembly, and the metal bracket it mounts to (I believe it was 4 spot welds) from an early Thirdgen (84 Z28 I think), Then went back to the garage and removed the pull down assembly from the Formula, and the metal bracket it mounts to (again drilling out the 4 spot welds), then we (my buddy and I) closed the hatch, and when it sat the way I liked he riveted the manual latch in place at two points, then another friend of ours welded it all nicely in place.
I will be doing this to any 86+ Thirdgen I happen to own going forward.
90sRSCamaro
Oct 26, 2020 05:55 PM
T-Ruxx
Mar 5, 2020 02:01 PM
gmanuel
Dec 29, 2002 10:44 PM
