help needed on a page from service manuel
Old Oct 27, 2020 | 12:01 PM
386kustoms's Avatar
Car: 1983 daytona pace car
Engine: crossfire
Transmission: world class 5 speed
i posted in another part of the forum but cant get any answers, i have a hot rod truck that i put a 85 tpi engine, trans and harness in from a 85 trans am. i have a problem where the truck dies down sporadically and i have to turn off and restart to get going again. im getting code 33 when i put the paper clip in and count flashes. now i looked up this page
85 TA SERVICE MANUAL 942.pdf
but my question is when i restart the truck the cel is not on, if i put the clip back in it still flashes 33 cods but cel only lights up when driving when the problem happens. so is that a code stored or not stored? you can see on that page i linked the first thing to do is see if code is stored or not stored, and if not stored i need to see the page that is symptoms section b. does anyone have a link to that page so i can see what symptoms i need to check out
Old Nov 3, 2020 | 05:41 AM
fuchs's Avatar
Car: T/A
Engine: v8
Re: help needed on a page from service manuel
Are you asking for this "section B" ? You'll find it attached.
A "stored code" means, that the ECM will flash that code after the ignition has been turned off, and back on in diagnostic mode.
Why don't you spend some more effort writing posts? Use capital letters, and more interpunction.
I had to read your post about 3 times, and I'm still not sure what your actual question is.
Luigytico09
Oct 1, 2015 08:46 AM
ranger77
Aug 8, 2009 12:58 AM
net_coma
Dec 20, 2005 09:26 PM
JimBow
Oct 30, 2000 07:59 PM
Black Beauty
Oct 23, 2000 11:06 PM
