Service Engine Soon
Old Oct 23, 2000 | 10:26 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
Service Engine Soon
ok ive read the article on how to read the trouble codes but i still dont quite understand how you know what code its displaying. i just got a SES light up today for my first time. please help me. thanks again. Rick
Old Oct 23, 2000 | 10:28 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
you are no longer untouched then
put your paper clip in
flash pause flash flash,pause flash pause flash flash, pause flash pause flash flash
is a code 12
following this?
Old Oct 23, 2000 | 10:46 PM
Vader's Avatar
BB,
Every code flashes three times, as 85 indicated. The first code displayed should always be a '12'. That is the first possible numeric code, and the codes will display in numeric order, not most recent of most significant first. Any other codes you have stored will also be flashed three times. When all codes have been displayed, the '12' will flash three times again, and the process starts all over again. The cycle will continue endlessly until the battery runs dead or you turn off the ignition.
As 85 explained, a single flash of about a half-second, then a pause of about one second, then two flashes in succession would be a code '12'. Three flashes, a one-second pause, then four flashes would be a code '34'.
Just write the codes as displayed on a note pad, then check them against the tables when you're finished scanning.
If you have Acrobat Reader, check this link for a code table and procedures:
GM Error Codes.pdf
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 23, 2000 | 11:06 PM
Car: 90 Camaro RS
Engine: 305 TBI
thanks for the quick response guys. ill let you know what the code is and you can help me fix it hehehe
thanks
RICK
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
