Mystery wire, probably radio related
Old Oct 27, 2020 | 04:16 PM
Hector Ostia's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Transmission: Automatic
I took off the panel under the dash to get a look at things under there and I noticed this loose wire fell out. It was probably from the owner before me as I have only had this car (1988 IROC) for a year or so. My radio has not worked since I got the car and I am thinking this wire might be why. Anyone got any idea what to do with it? It is yellow coming out and then ends brown/dark tan.
Old Oct 27, 2020 | 06:06 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Re: Mystery wire, probably radio related
Where is the wire coming from?
Do you have an alarm? If so, does the alarm have a trunk release button?
I have a similar wire from my hatch release on my early 90s alarm.
Old Oct 27, 2020 | 08:02 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Could be connected to anything, or nothing at all. You have to start taking things apart and looking to be sure of anything
Old Oct 28, 2020 | 01:08 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
That appears to NOT be a factory wire. Is it hot at any time? Is it grounded?
Old Oct 28, 2020 | 06:30 PM
Looks like typical PO-related hackjob SODOMY to me.
Follow it to its source. That's all you can do. Nobody out here is going to be able to read some PO's distant past "mind" (I use the word loosely) and just tell, oh that's the wire that hooked the doubletalk generator to the blast furnace and provided for the defibrillator to download the malware into the shifter. Yeah right. We're supposed to know that.
Old Oct 28, 2020 | 06:44 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The center console is pretty easy to pull. Trace to its source. The factory radio wiring is bundled into 4 separate connectors. That is certainly a DIY spade connector.
xiholdtruex
Car Audio
Apr 6, 2021 07:49 PM
84Camarodriver
Car Audio
Mar 19, 2012 05:36 PM
bigd077770
Car Audio
Aug 25, 2011 10:22 AM
Darkfire438
Car Audio
Jun 8, 2010 08:18 PM
Shookum2004
Dec 31, 2007 11:22 PM
