connector
Old Nov 18, 2020 | 12:19 PM
jpontiac's Avatar
connector
Hello
you have a picture of this connector?
I don't have the same colors
Old Nov 18, 2020 | 08:26 PM
Re: connector
Looks like yerbasic blower motor resistor connector.
Just go to the junkyard and gank one off of just about ANY 70s - 80s - 90s vehicle. They're all basically IDENTICAL as far as I've ever seen.
Old Nov 19, 2020 | 08:57 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: connector
The colors of that connector are the same as my 90 harness. Either they changed wire coloring or those wires aren't related. Judging by the spot in the harness compared to mine, I'd say they aren't related but that's merely a guess.
Old Nov 19, 2020 | 09:14 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: connector
Originally Posted by jpontiac
Hello
Those wires do not connect to each other. The top pic is the blower motor wires and they should go into the wire loom and end up @ your HVAC switch.
The wires in the second photo looks like either the original TPS sensor wires or the wires that would have run to the Air pump. I see your TPS sensor (from a pic in your other thread) looks to be rewired. Could also be for the knock sensor.
Old Nov 19, 2020 | 10:51 AM
Rogervan's Avatar
Re: connector
my 1985 eldo the climate control runs blower only on defrost and then back to other speeds and it works. controls that run the valve apparently do not control the flow.
Old Nov 20, 2020 | 01:34 PM
jpontiac's Avatar
Re: connector
I would have to find a diagram for the wiring of the blower motor
Old Nov 21, 2020 | 01:30 PM
jpontiac's Avatar
Re: connector
vorteciroc
Jan 2, 2021 07:58 PM
J.C. Denton
Jul 29, 2020 05:46 PM
88PontiacT/A
Feb 17, 2011 10:41 PM
astoria18
May 16, 2005 09:56 PM
jmd
May 13, 2003 04:45 PM
