Alternator rebuild concern
Old Nov 19, 2020 | 01:39 PM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
In the process of rebuilding an alternative, and noticed a couple differences between the two. It looks like im missing a ground and resistor (see picture). I think I figured out the missing resistor - difference between 1 wire and 3 wire alternators.
Still not sure if I need the ground. Any thoughts?
P.s. - the alternator missing the components is a Powermaster (capable of 1 or 3 wire operation), and the other is a duralast reman 3 wire). Both are 12si alternators.
Old Nov 21, 2020 | 09:16 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Alternator rebuild concern
I think the resistor is for cars that originally had volt gauge-resistor prevents backfeed from alty to ignition +.The strap from rectifier to terminal on back of alternator is for electric choke.
Old Nov 22, 2020 | 02:07 PM
potterc32's Avatar
Thank you for the helpful response! You're a saint!
jack1005
May 21, 2013 09:50 PM
IROCZdude
Apr 2, 2011 10:38 PM
noroxus
Jan 5, 2008 01:51 PM
88_Import_Slaye
Jun 11, 2005 11:35 AM
88ROC1LE
May 6, 2003 03:07 PM
