brown alternator wire
Old Jul 23, 2012 | 06:33 AM
jack1005's Avatar
i bought a new alternator and its not charging there are two small wires near my alternator a green wire and a brown wire im not sure what the green wire does but i think the brown wire is the exciter? can someone tell me where to hook this wire up on the alternator?
Old May 21, 2013 | 03:41 PM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Axle/Gears: 10 bolt with 3.73
Re: brown alternator wire
i know this is old, but they should hook up to a connector that plugs in the alternator. the brown is most likey an exciter wire that runs into the cabin and the green im not sure it either runs to ecm or starter.
Old May 21, 2013 | 09:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Bingo. Brown wire goes to the drivers side header plug, I believe it is C100. Brown wire gives the signal for the alternator to start charging/turn on.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
