Wiring HELP!
Old Dec 10, 2020 | 01:13 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Wiring HELP!
I broke a starter bolt and it took me some time to extract the broken stud... ANYWAY, when I got the correct bolt in, my battery was DEAD. I replaced the battery and now I have NO power. No ignition, no lights, NOTHING.
All the wiring looks ok, but I DID FIND a rodents nest on the motor mount- any ideas on how to track down the problem??
Old Dec 10, 2020 | 05:11 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Wiring HELP!
You will need to Pearce the wire with a safety pin and make sure it doesn’t ground but check power on each side of the fusible links at the starter.
Old Dec 12, 2020 | 11:07 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Wiring HELP!
If the starter was painted,..... you might not be getting a good ground. (Strip the paint from the mating surfaces and you will be G-T-G ! )
jason_yeast
Oct 29, 2011 04:42 PM
afterrsairbrush
Nov 2, 2009 06:40 AM
Whoboy580
Jul 1, 2007 12:41 AM
jeepguy553
Mar 25, 2004 01:20 PM
