Reverse light not working
Old Dec 21, 2020 | 01:51 AM
Alexstone0429's Avatar
Car: 89 Camaro
Engine: 305 NA
Transmission: 5 Speed manual
1989 Camaro Rs manual 5 speed
Reverse light does not come on when the car is in reverse. I have already disconnected the plug on the transmission, and connected a wire in the end plug to bypass it and then when I turn the ignition on, the reverse lights come on (Which means the wiring and bulbs are all good). So then I tested the plug in the transmission by using a multimedia and testing the continuity. When the car is not in reverse, and the multimedia connected in the plug, there is no beep. As soon as I put the car in reverse it starts beeping (So the plug works). This is confusing me as this proves both the wiring and the actual switch work.
So if anyone has any idea on what else could be the problem, it would be very much appreciated.
Old Dec 23, 2020 | 02:27 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
thgiL sereveR
Sounds like there is a bad connection between the connectors.
You probably checked for corrosion, dirt, etc.
There are options depending on the type of connectors.
1:— Conductive compound.
2:— Bend the pins.
3:— Coat the male pins with solder to increase the diameter.
Happy Racing!
I Just Learned About A Huge 75,000 Horsepower Icebreaker Ship. Hmmmm, Now How Can I Stuff That Engine Into This Funny Car Chassis
thunder57
Jan 5, 2016 05:35 PM
midge54
Jun 27, 2015 12:08 PM
RSTealer
Aug 12, 2014 11:31 AM
85irocr
May 13, 2010 07:33 PM
Twix
Nov 24, 2002 07:37 PM
