Keyless entry wiring
Old Jan 5, 2021 | 12:52 AM
Jordan Ruddick's Avatar
Hello I have a keyless entry system I'm installing into my 1985 sport camaro and was wondering if there's a specific power wire I should tap into since I can't seem to find a harness for a 85
Old Jan 5, 2021 | 01:12 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Keyless entry wiring
The fuse-box should have a "BAT" slot or 2 ready and waiting to be used; the schematic below is for an 85 Camaro. You just have to find a fuse-block connector for it, many early 80's - early 90's GM's used these things so that's what to look for in the local junkyards.
Wire will be ORANGE and the BAT plug itself will be black and look like this:
Old Jan 5, 2021 | 01:15 AM
thank you
Old Jan 5, 2021 | 01:21 AM
I think I had to put one of those in when I put in power windows it ran from the fuse box to the distribution block is it the same thing?
Old Jan 5, 2021 | 12:59 PM
John in RI's Avatar
You could 'tap' into power from the distribution box too,....... just need to use a different plug.
Old Jan 11, 2021 | 09:38 PM
Would anyone know where the wires for the parking lights under the dash are?
Old Jan 12, 2021 | 10:43 AM
John in RI's Avatar
Depends on the car you're working on. Since this thread is about keyless entry,.... you should start a new thread.
TinnMann2
Mar 10, 2017 07:11 AM
OutLaw305
Feb 3, 2004 11:25 AM
DaveK
Nov 1, 2000 07:45 AM
